AT&T Note 3: KitKat finally!
Battery life is either the same so far or maybe even better than 4.3.
If I go into the app store and try and update it.. it says its not compatible with my device?
Downloaded and installed over lunch! Praise Zombie Jesus!
Now what?...
Wait for root and switch out the god awful dialer with the Nexus version?
Hey everyone....a couple of update questions. When I go into my device info to check for updates, I get this message at the final screen:
Does this look right/ normal?
I think the update is still rolling out by a region/timezone basis. I think people are getting over that by setting their clocks differently and turning off auto sync time.
I tried changing the date manually ..went as far as april 30 but could not get the update..
I've tried the time change thing too. I'm in Austin, TX for the record.
There are many things that could cause issues with getting this update. If you continue to have issue after a couple of days, contact AT&T and they will push the download to your phone.
Me too. Can't figure it out. I've tried 5 times.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
I was rooted getting the same error. I unrooted and did a factory reset and still did not work. Went to Samsung area in best buy and they updated in about 20 minutes.
Sent from my SAMSUNG-SM-T217A using Tapatalk
I called ATT. They tried various things and at last told me they could not push it to my phone. They told me to wait for a few days as they are sending it in batches :(
If after a few days, it still does not work, then take it to a Samsung location (some say BEST BUY can do it) and let them flash the rom to your device.
Did y'all back up before installing the update? If so, what did you use? I keep getting notified about the update, and I'm thinking I may take the plunge soon and update. Just wanted to know if it'd be fine to not bother with backing up.
Sent from my SAMSUNG-SM-N900A using Tapatalk
I used Kies 3. I would still back up your photos to your pc...even though Kies should do it.
I've got them backed up to Dropbox but I can use Kies though it looks like a moot point now. It updated for me while I was sleeping.
I went ahead and factory reset my Note 3. I have concluded my battery life was around 2 hours less compared with 4.3. Kies 3 is now restoring from the backup I created. Hoping for the best.
Edit: Wow ! I guess this is a process that takes a couple hours. Still restoring.
Sent from my Samsung Galaxy Note 8.0.
So no update for me yet. I stopped by my Samsung station in Best Buy and they don't have it available to push yet. Samsung guy busts out his N3 and says "it's not available yet"....He then goes through steps to check for an update on his N3 and what do you know, there it is! I just laughed to myself as his face reddened. These are some of the times I miss my iphone......but barely. Lol
jeffnachatilo
