AT&T Note 4 updating... looks like Lollipop
Im jealous. Tmobile isnt even close to releasing the update.
Sent from my Frost White T-Mobile Galaxy Note 4
Im mad that the Note 3 got it first! 😠 lol
Yeah, pretty stupid. I can't believe it's still in the manufacture development stage. Wouldn't thing it would take months for them to get it done.
Ok, so anybody know how to stop the DL. I just walked into a WiFi area at work that I use sometimes and checked my phone and of course, my update is DL'ing, which I did not want to do. I shut off WiFi and it says it will resume once back in WiFi range. I don't want this to happen either. If it DL's and then gives the option of installing - fine, I'll deny the install however, I will still have over 1GB of space taken-up on my internal memory from the install files.
Are we SOL? Really there's no way to stop automatic system/OS updates on this device?
Yeah, I've never had the download start on its own so close after getting word on it. This doesn't feel like the usual staged rollout.
I would think (but I don't know) that the memory would be cache or app memory that could be cleared up somehow. I just scanned through cache and app data settings and can't find anything there. It may actually store it on the cache partition, but I'm not sure.
As far as installing it, I just got an "install now" or "remind me later" option when the download finished.
Started download with 93% battery. Downloaded and updated. 52% battery left. Took 2 hrs to download and I'm not a heavy phone user. If you plan on using the phone during the entire update than yes, use a charger.
Now that it's updated what's the big deal?
WOW this happened while I wasn't looking! Been looking for it and when I got distracted BAM!!!!!
Connected to the charger and downloading.
My only issue so far is a Google Services error that I can't clear. Says I have an app that needs updated but I'll be damned if I know which one
Have you tried clearing any cache partition to see if it helped?
I was reluctant to pull the trigger but I did and downloading. I'm at 46% and started at iono around 1 maybe. Work wifi not so stellar. Probably would had been 2/3 done on home wifi. But anyways the junkie in me had to get his candy fix.
Its downloading a 1161.38 MB update.... Look like it is likely Lollipop finally for AT&T
Of course its going very slow, so it will take a little while before I am certain what it is.
Either wait for the notice, or go into settings and manually check for an update. Change your date if need be (if you want to check again within less than the 24 hour waiting period), and manually check the update.
It's Lollipop.
If it's 5.0.1, it's not the latest version. There was a 5.0.2 update. Now, the latest version is 5.1. So why is AT&T releasing 5.0.1 and not the latest version?
That's the life of Android, OEM, and Carriers. By the time the OEM releases it to the carriers to have them rape it, Google is already do new updates and releases.
Guess I'm rollin' without WiFi for the foreseeable future.I have basically unlimited data anyway and my LTE is faster than my home WiFi so the hell with it.
drayb
