AT&T Note 4 updating... looks like Lollipop
Just as I'm getting ready to travel tomorrow on vacation. I'll just have to wait until I get bac. Maybe by then you guys that have it will have more findings...??????
Just as I'm getting ready to travel tomorrow on vacation. I'll just have to wait until I get bac. Maybe by then you guys that have it will have more findings...😄
Look at who's here in Android central. You still rocking a Blackberry?
Finally updated and it's very snappy! Like the new notification drawer. Battery stats pace looks better. Vibration on key press seems longer even though I shortened it but overall so far so good :)
Finally? Was it not updating before that?
Not that it should matter but nova just updated the other day so check that you are on the latest version. Could also be a prime thing if your using the free version.
Yes, I have the prime Nova. I did a hard reset and still doesn't show up. I have uninstalled Nova and re-installed it and still can't get it the swap down to expend the notification drawer.
Updated this morning, smooth sailing so far. However, is anyone else's oxygen sensor on the rear lighting up when you put the phone down on a light colored surface? Put it down on a dark surface, its fine, on a light surface the sensor lights up for a moment then turns off. Not a deal breaker, but annoying nonetheless. Uninstalled Google Fit like I saw someone suggest, but problem persists.
Finished my update this evening. Took forever to download. Update itself went smoothly. My phone seems to be noticeably faster.
Yeah I've tried 3 times. Every time it restarts and starts to update it goes to update failed. Guess I'll hold off for a while.
Downloaded it and so far phone is faster. Visually better as well. I like it. Is it an ART?
It definitely runs about three times as fast as before. So glad I checked AC this evening, otherwise I wouldn't have checked for it!
ihtasham
