AT&T Update 7/9
Got the update notification this past Sunday and after delaying it so many times it finally updated by itself smh. Started noticing my battery life sucks even more now!!! Can someone tell me how to clear the cache?
Turn the device off.
Hold volume up + home + power at the same time.
Use volume rocker to select clear cache partition.
Select power to accept.
Use volume rocker to select reboot.
The At&t update for galaxy s6
Is there a reason we haven't received the 5.1.1 update because tmobile an sprint have so wth is going on
Posted via Galaxy S6 gold 64gb Att
No idea what is going on. AT&T pulled the most recent round of updates.
Any tips if you never received this update? I am still seeing build number ending in OCE. When I do try the update, I get an Interuppted - try again in 24hours error.
My build number ends in OCE too. The past few days, I also get the interrupted-try again in 24 hours error. What is going on with AT&T?
Must still be trying to track down the speaker/audio issue while on a call that cropped with the previous AT&T device update.
I'm still trying to figure out what this update did. I'd rather have 5.1 which fixes some issues in lollipop itself
You're not alone in this
Posted from my Samsung S6 Active
noroldie
