August 5th is closing in!
The FPS is the concern. Most of the glass protectors don't work.
This is why I'm very hesitant on buying the Note 20. The ultrasonic fps is very finicky under good conditions and just bad under sub optimal conditions. I wish Samsung would ditch the ultrasonic fps and move to the optical fps like OnePlus.
No apologies... I did ask. And it sounds like a cool pairing with the watch and one of the reasons why I like the idea of the 12 Pro.
Thanks for your well wish... but I spent the last month at home with symptoms (one was losing 20 pounds in a little over 2 weeks) even though I took a test two weeks in a row and each time showed negative. Back to about 92%. Crazy experience I hope people will be able to avoid and everyone here stay safe, be healthy to enjoy new phones :) I think I should be bulletproof now to make a trip to BB and check out the Note. Still gonna carry a ton of wipes with my mask. :)
Yikes, that's not good. Ever figure out what that was (only if you feel like sharing!)? Thankfully Best Buy requires masks and social distancing so yo should be okay to go!
No, I have a Note 8 so I still have the FPS in back. Yeah using in under glass FPS will be test when I get the new phone.
Absolutely. Finding the right screen protector is key. You said you bought one from Spigen? Are you using a phone with an in-display fingerprint sensor and if so, does it still work with the screen protector being applied?
Getting Black, no sense for me to get the other colors as i always put a case on it , and will get a Dome Glass screen protector, Dome works great on my Note10 Plus since first got it on August no issues at all Dome is been always great on all my other phones.
I case up too, but always clear. I haven't done a screen protector in a few years now. I thought about the done, but was scared to screw it up and waste money.
My Note 8 has been the most slippery phone I have ever owned when I take out of case. I really loving the look of White and would love to rock that naked at times... but I expect it to be as slippery.
Well I think I'm going white and I'm going naked...
I haven't needed a screen protector for my Note 10 plus so can't see why I would need it for the 20 with the even better gorilla glass.
Size size I think it will be difficult even with slim cases and that white or maybe bronze would be a shame to cover.
Honestly, I feel it was two false negatives. I know it sounds odd but when you go through the testing procedure it may not sound as unlikely. One was at CVS and it was self administered and I did my best to really jam that swap up my nose and swirl it... both sides. But second test was county run and they were the ones to jam the swap and take sample. But both tests the first two weeks of July took almost a week to get result.
Crazy situation but I think I had it... had enough of the symptoms.. chills, muscle ache, lost 20 pounds, etc... even lost taste in food... that was the worst when a T-Bone steak doesn't taste like a steak... or whatever your favorite food is... makes life miserable. But feeling back to normal.
I'll take a Antibody test next month to make sure.
Sorry to others for being off topic.
I'm glad you're feeling better now. Stay safe.
...... apparently Corning has been able to improve BOTH the scratch and shatter resistances. In the past we were y told they were almost inversely proportional.
In general, most materials are. For example, work hardening a metal will provide greater strength but will become more brittle. But if you change the alloy content and/or crystal lattice structure of the base material, you can shift the properties. Glass has some similar properties (as do most materials), but due to the inherent properties of glass, work hardening is not likely an option. It's likely a combination of chemical composition and heat treatments. It's possible their patents might provide some insight.
Uff. Head says no. ****e exynos at full price ( c£1300 , $1700 if the rumours are true ) with zero incentives or deals.
But heart says the usual- what else can replace a note? There is nothing close on the horizon.
Was even toying going mid ish range for a laugh - Pixel5XL if it ever materialises, OnePlus 8TPro if it materialises or something now getting reduced from a couple months ago - Oppo X2pro, Mi 10 Pro.
Can always wait and import a Note20 Ultra SD , but that has its own headaches.
As with every single note, ill probably just click buy anyway.......
That hurts :(
EGGGSSSACTLY! I mean Bruh?! It's a Note! What has everything the Note has in a single tiny package? It's the perfect device for me.
With that said, I always trade up, get employee discounts, and use points, so I'm not coming outta pocket like that. Even so, Notes and tabs are my guilty tech pleasures. A once a year tech splurge doesn't hurt. It's buying cars every 3 years.
Very well said! Lol
Exactly. I think most in the US would get a BIG shock if they had to pay what we do. Can only dream of those prices, deals and incentives.
Still do it though. Every single time. .
Being that it's more secure, I doubt Samsung will ditch the on screen ultrasonic fps for an optical one. It was one of their selling points at one time. I use mine with the Whitestone Dome and I've learned to be content with the fps performance. lol
djkodi
