Auto Rotate does not work.
Mozillo
Active member
Jan 3, 2014
34
I never had this problem until recently, lately my tablet's screen is stuck in portrait and it won't rotate at all, I have auto rotate on and tried turning it off and on and nothing. I even factory reset and nothing.Does anyone else have this problem? Is this some bug that can be fixed with an update?
Sent from my Nexus 7 using AC Forums mobile app
It never rotates anywhere. I tried the cache wipe just now and it's still not working.
Yeah nothing you suggested work. It was working fine before I don't know why it stopped working.
It started working again for some reason. I will update if the problem occurs again. Update : now it doesn't work again.
Every time I shut off the tablet overnight the auto rotate will work again, but it will lock again later on.
Yea get that app and you can leave it on auto for most of the time but when you need it horizontal and it won't leave Vertical it's 'a good hack.
Is it specific applications? In the application manifest you can specific that the application can only be used in specific orientations.
No it's everywhere that auto rotate will turn off and on randomly.
Had same issue and finally realized it was the case causing the problem. After I removed the tight fitting snap on case, the auto rotate worked fine and kept working.
I don't have any cover or case on mine and the auto rotate is flaky. Sometimes it works and sometimes it doesn't. Sometimes a reset fixes it for awhile and sometimes it doesn't. Also the touchscreen will be non-responsive when trying to unlock at times. My wife's Nexus 7 is experiencing the same issues.
I have the same issue, I just turn it off and on again and the feature starts working fine some app or function causes it (my own assumption) as the time between it happening again is different. I dont know which app
Still having this problem? I have the same thing happening. Called Google while still under warranty and they said it was because static builds up on the accelerometer and requires a soft reset. Turn the tablet off. Wait a few minutes. Press and hold the power button for 30+ seconds (let it cycle through turning on and off) and let it finish it's cycle to off after holding it for 30 seconds (thus the +). Power it back on and it should be fixed.
I still have to do this every day or so, so it is not a complete fix. I notice it locks up sitting in my case and stays fixed longer if I wipe out the inside of the case and back of the tablet with someone damp (attempting to remove any lingering static).
I removed my covet and the rotate still doesn't work, even temporary work, should I just sent it in? I sent it in before and I got it around January 2014 so Is it still under warranty.
Use cleanmaster clean junk clear ram...
Settings>accessibility>Untick Auto rotate>restart, Wait 5 minutes turn back on then tick the auto rotate in settings.
funkey_d0
