Auto USB Drive mode on connection to PC
dietrichmd#AC
23
Title basically says it all...My epic, when I plug it into the PC, automatically goes to USB drive mode. Funny thing is, I still get the prompt to ask what I want to do. Of course, any choice here is meaningless. Any ideas?
Sounds like you might have an app that is overriding this. I know the new WinAmp app has an option for this as does certain lock screen apps. Make sure you don't have an app that has this option checked off.
Winamp Auto mounts to USB mode, If you recently installed WinAMp player, go into settings and disable Auto Mount.
I was having the same problem after installing WinAmp.
tuananh3105
