aznmode
- Jun 7, 2010
- 449
- 9
- 0
Can I flash 1.8 over 1.7? Or do I have to do a wipe?
Sent from my evo using Tapatalk
Says to wipe but may not have to on Baked site forum. I would just do a complete wipe just to be safe.
i downloaded it and couldnt tell what was new??? anybody have a change log??
I had 1.7 and I flashed 1.8 without any issues... my suggestion though is after you do the flash you install a CPU monitor app and a set CPU app so you can under or over clock as you like. I say this because the first time I wiped and cleaned installed 1.8 my phone seemed to operate slower that it did with 1.7... I believed this had to do with the design of 1.8 under clocking the CPU to achieve more battery life. The second time I installed 1.8 I just flashed over 1.7 and set my CPU range from 450Mhz when the screen is of , 800Mhz when the screen is on....I obtained the ROM from xda developers but now its been removed. Good thing I saved it.
