I haven't seen anything like that. Have you tried a cache clear in settings?
Yes. I always seem to not describe that clearly.Do you mean clear "Cached data" under "internal shared storage"?
No sweat. See you around the forums.I cleared the cache and reboot. It worked! The battery life is back to normal. Thanks so much for your help...
Yes, I was noticing something similar as far as battery life. I'm outsidefor work all day and never on WiFi. Before the update I would end the day with 4hrs on screen time and 25% left. Now it's been a week and checking every day the same result. Barely 3hrs on screen time and 30% left. All has been on Verizon LTE and no weak signal. I thought it was just me.
I too have seen a slow decline in battery life within the past couple of weeks. I'm on at&t. Hopefully April update will helpMy battery still seems to have taken a hit since the update. I've lost a consistent 45min on screen time based on what I was getting before. Same routine and same locations. All on Verizon LTE. Unless the update affected my signal strength, I cannot see what else would cause this. No new apps
My battery life has steadily declined the last week or so, recent beta update has made it way worse
