Battery drain.
baja141
47
Did the update to my phone and now the battery draining like crazy. Any suggestion. Need help . Have the extended life . Getting about ten hours.
Yes, shut down, pull the battery, wait 2 minutes, put it back in and boot up.
That should help. I got the update as soon as it was offered and I am getting great battery life. I went from full charge to 50% after 15 hours on stock battery.
Did u install any new apps. Make sure that blockbuster app is not updating in the background
is your auto sync stuck? also, are you in a fringe 4G area? If the first, try disabling auto sync and see if battery life improves. If the second, try forcing cdma only and see if it improves.
tota
