Battery Drain
A
AC Question
I just got my S4 a month ago. yesterday it got extremely hot and the battery drained 40% in 2 minutes. Can anyone help me?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,657
4,797
113
Welcome to Android Central! Has this behavior continued? The battery might be failing. Take it out, lay it flat on a table, and try to spin it. If it spins freely, it's bulging in the middle, which is a bad sign--try a new battery.
A corrupt SD card can also cause behavior like this. Unmount the card (in Settings>Storage), remove it, and reboot. You could try a different SD card, as long as you know that card is good.
Screenshots of the battery stats would be good, if this happens again.
HelloThere
