Battery drained problem!
Dec 16, 2013
6
Hi there!
I'm using Galaxy s4 mini for about 4 months now. Everything was perfectly fine but 2 days ago, when I updated the software which is compatible with galaxy gear, the battery is running out very quickly.
For example:
Its battery was 34% when i was using it last night. After playing game for about 10 mins, the battery warning message appeared saying that the battery was only 4% left. During the time i used it, I noticed that the screen was even hotter than normal.
Today, I used it when there was 24% left, still for playing games and it was the same as yesterday (heating problem, battery drained quickly), but it was 'better', 10% left.
Anybody knows what happened to my phone pls help me!
Many thanks :)
Hi there!
For example:
Many thanks :)
Have you had a look at your battery statistics?
I had but I didn't find anything strange. I usually check it, mostly the battery spends on the screen, cell standby, OS... it's perfectly fine, right?
Seems okay...
Not sure then. Very strange indeed. Sorry I couldn't help more...
This happened again!
90% down to 78% for only about 15 mins playing games @@ Before, it only took under 5% for 15 mins.
I really can't stay calm :(:-!
liquidsnake757
