Battery draining after 4.3 Update
In terms of account sync, what do most people leave sync'd? My battery flat out Sucks since the update.
Sent from my HTCONE using AC Forums mobile app
You have a rogue app, the awake time and screen on time are pretty far off. Something is running after you turn off the screen...
Those with battery issues......see in the AT&T threads those with battery issues after 4.3 are disabling Google Maps and getting 400% better battery life...I'd try that and see if that's the culprit....If it is, then decide if you can live without google maps on your phone till it's fixed
Thanks for the heads up. I just uninstall ed maps. I'll see how it goes.
they were "disabling" go to settings / apps and hit disable, it will still run if you uninstall updates
I believe I figured this out. After the 4.3 update all the Google location services got turned on. And that is what is causing the battery drain. After turning them off, battery is discharging at a normal pace.
Thanks! This worked :)
Miserydhala
