battery draining while plugged in?
zorian99
136
18
does anyone else's phone battery drain while using it (with 4g on) and it's connected to outlet?
Are you sure your plugging it in all the way? I noticed that when I plug in my charger it goes in a little more than halfway so I think its plugged in properly but its not.
Make sure your using the charger the phone came with. Some other chargers wont work as well.
the little charge icon shows up so it is charging but the battery level drops while using it.....i'm wondering if i need to trade this phone in for a different bionic or if 4g/lte really using that much power
As someone else said, make sure you are using the charger that came with the phone.
Are you using the original charger? I've had that happen before with other phones with cheap 3rd party chargers and when I swapped out the charger it worked fine.
It depends on what you're doing, but it is possible. Check and see if the phone is hot. Sometimes if the phone gets too got it won't charge as a safety measure. Some people have reported the phone getting hot on LTE so that could be the culprit.
RohitPatidar57
