Battery extended vs standard with cover
Apr 26, 2010
4,338
263
83
has anyone used the standard battery with the extended battery case?
I am going to be photographing an all day event and don't want to carry two phone backs with me.
I have a portable xcel usb charger, but wanted to still make use of my standard battery.
Thoughts?
I was thinking of using a folded business card to hold it if it wiggles....
I believe Phil mentioned that the standard battery fits in there just fine with the extended battery cover and does not wiggle at all. While I've been meaning to try it I've never needed it.
I have no issues doing this. Mine has never came out or anything.
I got it to stick just fine, but I don't know if it would last all day that way. It was a tight fit, plus it just felt funky.
My suggestion is to use the extended battery cover with both and just get something to wedge the standard battery in there so it doesn't move.
I've tried it before, and it does fit. Not sure how well it would stay on since it kind of bows out a bit.
Pettywife
