The past two charge cycles my battery just dies. I don't notice it until much later when I check the phone and it is off. Anybody else have this happening to them?
I recently did the Verizon OTA update on October 4 (well, it was automatic) - not sure if that is causing a problem. That happened about a week or so ago, and this abrupt battery drain has surfaced just in the past 2-3 days. So, as far as I can tell after the update my battery was fine for 1-2 cycles.
Checking battery usage, it doesn't show any programs or apps that are causing this battery drain. The battery level simply drops off on a steep line down to zero. Cell standby says time without signal is zero. I have no idea what's going on. It's still taking 2-3 hours to charge, so it doesn't appear to be a calibration issue.
I'm not even using Mobile Data most of the time. My usage behavior has not changed in 3 months. Settings aren't the issue here. Something seriously bad is happening.
Is there an app I can use to monitor and log usage to figure out what's going on?
