Battery, help please! !!
Hail6
Active member
Dec 5, 2012
42
I got my note 2 right before Christmas. .. battery was awesome until about 2 days ago.... I don't even get 2 hours of screen time and before I'd get 6+ sometimes. .. can someone helo me please!!!
From my Note2 to hopefully yours
Do you have screen brightness on auto or set to a percentage.... auto will drain your battery faster. What programs do you have running in the background? If wifi is on and your not near wifi then your device will constantly look for wifi and that too will drain your. battery.
Anything unusual showing under battery use (Menu, Settings, Battery)? Did you happen to install any new apps around the time the increased battery drain started? Any noticeable change in signal strength (poor signal can cause increased battery drain)? Are you using the stock Samsung 3100mAh battery or a third party one (trying to rule out bad battery)? Also, below are a few apps that help troubleshoot what's going on with battery drain:
CPU Spy:
https://forums.androidcentral.com/e...details?id=com.bvalosek.cpuspy&token=EAG41u7d
BetterBatteryStats:
https://forums.androidcentral.com/e...ksven.betterbatterystats&hl=en&token=kvdxVsbx
GSam Battery Monitor
https://forums.androidcentral.com/e...ps/details?id=com.gsamlabs.bbm&token=cjDEYJvy
schm3ndr1ck
