battery is taking forever to charge
qmtc83
Active member
Jul 10, 2010
29
So the last two weeks it takes my phone on an average of 10-15 hours to charge. Its not showing it's charging slowly. I know it's. It my cord cause my cord works for my wife's phone.. What could it be.
Are you using the cable and wall unit that came with the device?
Yes I am. Its the only one I've ever used for it.
Wall unit might be defective. Possibly even the battery. Have you contacted LG?
From an AOSP M8
Not yet was hoping I could find a fix for it on here first before I delt with that. Maybe I'll try and get sprint to bump my upgrade up for me and I'll just upgrade to the nexus 6
Going to a different phone because of a charging issue is a bit dramatic isn't it?
Mine had gone from 7 to 77% or 10 to 80% in an hour on average. If the charger works fine then get the phone replaced through Sprint under their warranty. Or just get the N6 lol
Haha maybe. But I was gonna upgrade anyhow after the first of the year just thought they might bump my upgrade up instead of replacing it. My phone use to charge in bout 3 and half hours tops and now it takes at least 10 that's just crazy.
My G3 charges from 0 to 100% in about and hour and half. Ive only used the charger that came in the box with my G3
Posted via a Rooted AT&T LG G3
That is crazy. Are there a lot of apps running during the charge? If not, get it replaced asap.
No there won't be nothing running at all. It also does it while I have it turned off.
Have you all noticed that some LG G3 come with a 1.200 mA instead of the 1.8 one? You need a magnifiying glass to find this out.
Any update on this? Your carrier or LG should be able to send you a replacement battery and charger under warranty.
I traded for this phone so I don't think k can use the warranty. But it still charges the same way.
Something is definitely defective with your device. Either the charger or the cable (I'm replacing my gf's as of today after her original cable 'slowed down charging' just recently) or the devices battery may be at fault here. Have you ruled any of these 3 out yet? I'd give it back to the place or person you traded it for!
reblkari666
