Battery life concern. Is this normal?
GSam battery in the Play Store.
Opps. I meant more stats within gsam app without rooting the phone.
What info should I be looking for within gsam?
It will show your signal , on wifi or data
Give it full 24 hours to report stat from 100 percent that way we can diagnose correctly like how you did with stock battery built in monitor.
My battery was pretty bad after the first 3 days with my Note10+. Then after about a week from there, it improved greatly. I did have to wipe and only restore contacts, calendars, and messages. Everything else I had to reinstall manually. My main issue was Android System app. I have also basically disabled a good majority of my apps from running in the background.
Bruv29
