Battery Life/Tips and Tricks
i dont know, the iphones i had the battery lasted longer.
I hope a good bigger mah battery comes out soon.
does anyone know if these aftermarket 1500mAh last longer then the stock 1350?
1500mAh Battery+Desktop Dock Charger For HTC Inspire 4G - eBay (item 370484776473 end time Mar-17-11 03:40:08 PDT)
Stock on the Inspire is actually 1230. As for the link, I don't know - their description specifically states "Best replacement for the original battery with comparable standby and talk time."
So, the way it sounds to me, you may not be gaining that much extra time even with the extra battery size.
Also, despite the overall good reviews on the seller, my cynical nature gives me pause over a "larger" battery that is being shipped directly from China for $9.00 total. But that may just be me.
After complaining all day yesterday about the battery life (granted ive been using it non-stop because its new) I lowered the screen settings and got an application killer. So far the phone has been lasting me most of the day. I havent been on it as much either due to school/work
ya thats what i was thinking, as cheap as it is i might risk it if no definite better batteries come out soon and get the ohm meter out and see what its actually pumping out.
So you get better battery life out of the inspire than you do the iphone 4? which do you use more? It seems the iphone 4 battery would last a lot longer
My i4 battery will out last the Inspire easily
uobuob
