Battery life
firstmate963
13
Anyone know of a good extended life battery for Thrill 4G? Stock suxs bat fast.
Sent from my LG-P925 using Tapatalk
I found one on Amazon just got it today burning about 8% an hour on heavy use.... I will keep you posted.... its from ZZcell 2650mah... the included battery cover feels nice and I'm liking the thickness of it more
Well after 12 hours of heavy use... the last hour on full brightness and playing asphalt 6 to kill the battery cause I still like to kill them fully twice... the batter was a champ my old one I would be lucky to get 6 hours out of handbills would hold myself back from using the phone because I didn't want the battery to die.... today with this battery really did the trick and I'm very happy with it.... hope it holds up and continues to do just as good a job as day one
Is your phone unrooted? I dont get anywhere near 6 hours on standard battery.
No its not but like I said I had to hold back on really using it.... if I babied it it would get 6 hours on the standard battery..... now I have no trouble pulling 14 to 18 hours (depending on gaming or not) out of it with this extended battery
That sounds like the battery i want. Not to be a pain but would you mind posting the direct link. I have seen a few on Amazon, but it was a 2600 mah and not a 2650 mah which is the one you said that you have. Thanks
I did purchase the 2600 mah from Amazon and found the backing to be alittle more bulky then i wanted. I found a Seidio and its a 3200 mah and i got it yesterday i like the backing alot better. Granted i did pay 70 $ for it. Its worth the money. The site is seidio.com if u want to check it out. Thanks for your input
Sent from my Thrill 4g
Ashok Dharshan
