Battery Obsessiveness
Thanks - both are stopped and disabled. It must be something else. I also have my google sync's down to just emails for the most part. It really is annoying.
What carrier are you on? Have you noticed a difference in that particular wakelock when you are on wifi/vs cellular? Does it come back after a reboot?
Since I use moto assist I would opt out of freezing that correct? Sorry if that seems like a dumb question
Yeah, don't freeze any of the assist packages and possibly the Motorola DriveActivator. Not sure about that last one, you could test it out with it frozen and see if assist still works. It seems like it could be needed but again, I'm unsure. I don't use assist.
Hi - thanks for the help. I'm on VZW. This wakelock seems to be associated with WIFI and no cellular (as far as my limited observation tells). It does come back after a reboot, but again seems to be more of a wifi related phenomena.
Yeah man, that seems to be the issue that people are reporting about with certain routers causing excessive idle drain. Unfortunately I don't have a solution for you other than turning off WiFi when not using it or swapping out your router. It's only certain routers that cause that problem, and off the top of my head I don't know which ones don't. I wish I could be of more help but as of right now, nobody knows how to solve it aside from the two options I already gave. If I learn anything else I'll certainly update you.
tinni99
