Battery usage problem - call Name ID app
  • Start date Start date
A
AC Question
I just got my first smartphone, silly, I know. When I look at the battery usage 37 % is being used by Caller Name Id, which came installed but when the free subscription ran out I did not subscribe. I cannot seem to uninstall or disable it. Cell standby usage is 31%; if i touch cell standby it says battery used by cell radio 31 percent, time on 14 hrs, time without signal 0, connection time 5 hrs. Help, please???
You should be able to disable the app as mentioned above by going to app manager in settings and going to the "All" tab and finding the app.
Or you could long press the app from the app drawer and drag it to the App Info option at top of the screen to open it straight up to the menu where you can disable / uninstal it.
