Battery
patruns
3,241
89
48
Since one of the last updates it seems like my battery drains faster during the day. Last night when I put it on the charger it was down to 40%. I usually end it the high 60s and I was not using it all day.
Actually, yes. I noticed the 2 largest app usage was Chrome and Facebook, in that order. I was a little surprised that Chrome was higher as I really didn't use it all that much, especially when compared to Facebook.
That raises the possibility that Facebook is misbehaving (and perhaps it's causing Chrome to as well, since it might be accessing the browser). Try uninstalling Facebook temporarily.
Reactions: Laura Knotek
I think I figured out the Chrome part. I view Google News and I believe it's just a link to articles on the web. That explains a lot. As to Facebook, I admit to being on it quite often. Still, I feel like I am getting somewhat less battery at the end of the day than I used to and I attribute it to one of the last updates. Maybe next month's will help.
I had noticed a little more drain on the last update, but apparently it got fixed with the latest. Standby drain is gone, just got home from work, phone off charger at 5 AM and 89% left at 5:40 PM.
I would disable Background processing for FB and Chrome for a couple of days and see how much it changes. I bet this is a combination of low-quality signal and background processing, cell radios are very hard on the battery if the signal comes-goes (this part isn't always obvious, it seems good at one place in a structure, but is terrible in another part). You can use an app to track this over a day, but it's also hard on the battery, but can be pretty revealing.
The downside to disabling FB background is that it'll take a few moments to refresh when you open it, not sure there is a downside to limiting Chrome background.
Use Facebook on a browser. The app is a battery hog. If you need the FB app, log out of it and then log back in when you need it, then log out. Sometimes I need the app but not all the time
Reactions: B. Diddy
heritagevines38
