Battery
Krolt
237
10
18
Hi guys, I was getting two days (48 hours) with two hours screen before Marshmallow, I'm getting just over half of that now, battery stats are about the same?
I have wiped cache partition and removed most apps, is it worth clean install or accept 24 hours with 2/3 hours screen.
Cheers
Do you use your phone more in one day than you used to? You said you were getting 48 hrs with 2 hrs screen on time before marshmallow. Now with marshmallow you get 24 hrs with 2/3 hrs sot.
I get around 24 hrs with 2-4 hrs sot. It all depends on service strength, and how I use my phone that day. Its a lot better with idle battery usage than before marshmallow though.
yeah I used to get fantastic battery life with the two previous Androids. It's not 18 months old yet so should be okay (my Nexus 4 is), I did move 6 months ago so could be signal I guess
Thanks for the reply
trixie909
