Battery!!!
legin111
187
I'm getting great battery life from the S7 and just thought that I would share. I got a Canadian (Toronto, telus) phone so the it's the exynos version. Today is my third day with the phone and I started to put it through the paces. It's a slow day at work so why not do it now.
WiFi on, BT on, AOD, brightness set at 50. I've watched two movies from Netflix, browsed on chrome, IG, Amazon, ebay...etc. Played boom beach as well as a bunch of small things.
Coming from a G4 with the same size battery, it's killing the G4.
Phone came off the charger at 7:30am, and as of right now I got 6:40 SOT and radio on for 10+ hrs.
I'm really digging this S7 at the mall moment.
My only complaint (and not the first 3 charge cycles) is that you should recharge at 40%. Other than that, it looks as if you got a keeper.
How did you adjust to the 5.1" screen when you had a 5.5"? Also the front buttons are reversed and you can't move the app tray...LG fanboy here debating between this and the G5. Would love to hear your thoughts.
Yeah I'm definitely impressed with the S7...I had the S6 for a week and had to take it back because I couldn't get past 7hrs with minimal usage. That's when ibgot the G4 with the extra battery so I wasn't concerned about the battery at all.
I never really take it down that far but usually about 15-20% and then charge it up...I also do random charging as well, sometimes at 75% and others at 35-40%
koltyn
