Beautiful Widgets beta
My Xoom isn't rooted, so I can't use any of the screenshot apps that I know of. The widget isn't that special though. Slightly bigger and the same style options you're used to.
Works nice.
This screen cap app not so much. Ill use the sdk give me a few.
Sent from my Xoom using Tapatalk
All works great but when I tap the weather to see the extended forecast, the widget force closes
I'm not getting a force close when I tap the weather icon on the widget, or when I tap the extended forecast which brings me to weatherbug.
So if someone hasn't bought bw, can they use this beta?
I got it to work, thanks.
BTW I linked to that droidlife blog because that was where I heard about and I was trying to duplicate his screen. I like the way circle launcher makes a link to your apps and keeps your home screen clean. Later I might change the words to pictures for icons.
Now if I can figure out how to get clock off of the 24 hr format I'd be very happy. Itried the settings and checked the toggle to 12 he. But it didn't work.
for weather: Try touching the minutes on clock, this should bring up a menu, on left click on weather, on right, click on provider service and change to accuweather instead of Google this should help.
for beta I believe you should be able to download it without buying a previous version. Its a free download so it doesn't hurt to try.
Is anyone else having issues with the transparency? I can't get it to change regarless of what percentage I put it on.
Don't update the app when prompted! You lose the beta and your clock. I'll reinstall the beta.
Love these widgets. The menu that pops up when inserting a toggle widget is blank, though. The menu items do what they're supposed to do, so I just went through each one to find out what they were, lol.
Sobble
