Beeping While On Phone Call (Not An Incoming Message!)
No, but the "solution" provided wouldn't have worked anyway as it "fixes" a completely different problem.
So I figured out what the beep was when I made a call and heard what sounds like a call waiting tone, it might be a different sound or beep for different phones, mine is an LG premier, it is the data roaming, doesn't matter if you are roaming, if it's on, I get a beep, I turned it off and no beep... Wa La!
My phone beeps while I am talking on it. I have call waiting turned off. The beeping noise is very loud and the one I am on the with, we cannot hear each other and hurts my ears to no end. If anyone is able to help you with my issue I would immensely appreciate it. Thank you for your time and support.
Cheryl Montgomery
Cheryl Montgomery
Did you already read through this thread and try the suggested solutions?
I changed on the voice recorder app to off. Haven't been on phone since. A tip from google when i asked for help (?)
p.s. Last discussion should have been if anyone would be able to help me.
I was asking if you had read through this thread first, before posting your question, since there are other proposed solutions (including checking to see if you have a "minute minder" option turned on). Can you confirm that you've checked the possible solutions mentioned here and that they don't help? If so, can you give more details about the beeping? How frequent is it -- every few seconds, or about every minute? Is it a simple beep, or is it a distinct group of tones? Does the other person on the line hear it, or only you?
Ltcharensey
