Being a Nexus, is a return to stock necessary for Verizon swap?
Mr.Gadget
319
8
I think I am going to swap my 2nd Nexus out, this time from Verizon (not Amazon Wireless as they only do one swap, else change phone all-together). Do I need to return my phone to stock or since it is a Nexus can I just bring it in?
I'm just going to do the swap-o-rama until I get one that keeps its signal cause I like the phone too much to get a different one all-together.
NickA
1,617
117
63
Re: Being a Nexus, is a return to stock necessary for Verizon swa
And don't forget to wipe the SD card in case you have personal pics and info on it.
So you got the phone from Amazon but returning to Verizon?
anon(596177)
1,189
105
Absolutely. Unroot and lock it up.
if you dont and they check your phone your warranty will be void, and if they had alreday sent you your replacement phone before you sent yours off you will probably be billed for the replacement because of it (worst case scenario)
Yah, lock that sucker back up.
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Well they have to exercise their right to void it (it's not automatically void). I presume that they would, however.
Your SDcard gets wiped when you relock. Use something like Wug's to take it back to stock, and make sure to save everything you like--pictures, downloads, whatever, on a computer. I literally have a folder for such an occasion on my Mac :).
Mr.Gadget
319
8
I originally purchased my GNEX from Amazon Wireless. They sent me a replacement phone already and I returned the old one. I called them back, but they said they can now only swap my GNEX for a different model and that if I wanted a swap, from here out it would need to go through Verizon.
My local Verizon rep told me they could do it without charge, but I may, or may not, get a refurb. But, I'm OK with that I guess, as long as all works fine and it wasn't dragged across crushed glass and broken nails before I get it.. hehe
dmmarck
Retired Moderator
Dec 28, 2011
8,349
2,594
Yeah, they're really good about swapping. Just go over the CLN replacement w/ a fine toothed comb and you'll be fine.
FABETTTTT
