belt case, S7edge
bialy
344
What is best belt case?
I have this case version linked below for my olde iPhone4s and is pretty good; it swivels 360 degrees but I think 180 degrees may be better to avoid it being upside down?
The s7edge goes to case naked so I wonder if that is not enough protection when it comes out, as smaller iPhone may be sturdier than S7e.
Any specific suggestions?
New Leather Case with Rotated Belt Clip for Samsung Galaxy S7 S7 Edge | eBay
Does wireless charging work with these 2 cases above ?
Do the above cases defeat the Edge screen function / visability ?
Yes. Wireless charging works with the Supcase Unicorn Beetle Pro.
And yes. It works with wireless charging.
I am using the zagg tempered glass. they said they are coming out with a new version "soon" that is case friendly but i doubt it.
zagg tempered glass and unicorn beetle pro seems like the ultimate combo it's slightly thick but very manageable
Are you looking for a case and belt clip that are separate (where you pull it off the belt clip/holster and it still has a case on it or one where the phone is naked after you take it out of the holster?
Just before the second Note 7 recall happened I had ordered myself a black leather belt holster off Amazon. Its worked well for the temp phone I've been using while awaiting my S7 Edge, and should work just as well for the S7E as it did for the Note7:
https://smile.amazon.com/gp/product/B01I7WEDPA/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
A.O. - thanks. The case you linked is very similar to the link I put in OP - can you put any type of additional very thin protection on the naked phone so that it still fits in case, besides a plastic screen protector or tempered glass?
For the type that still has a full case on it (like Otterbox Defender, Beetle), I'm trying to find one that is the least bulky. The ones I listed (Otterbox, Beetle) seems too bulky. Any non-bulky suggests?
I like naked phones, as smallest footprint and no reduction is screen sensitivity and nice feel etc (my current one is naked but very old so I don't care about dropping; actually I drop every couple months and no real problems but it is an old, small, thick sturdy one). For an invest in a pricey S7e, I should try to protect better for the first couple years especially since it is more fragile.
The leather holster I linked works with phones that have have any type of screen protector (they are so thin that they don't effect the fit). The holster works with naked phones as well as ones with cases. With no case its not so loose that it notably shifts around, and with a case its not so tight that its tough to pull out. Overall it seems like it works pretty well for pretty much any configuration of phone, case, and screen protector you might have. I got mine to replace a horizontal style one from a different manufacturer that had the case tearing where the clip attached. This seems much better built and shouldn't have that problem. I'd say if you're planning to get the one in the OP make sure the dimensions will fit what you have. If you're worried about the depth then adding the depth of the phone + the depth of the case + thickness of screen protector together tell you how deep the holster would have to be at a minimum, and to be on the safe side I'd go with somethings some extra room beyond that combined number.
A.O., for your S7 edge (or temp Note7), are you putting it the that case naked, or has an internal case 'round it?
If naked, worried about a fall out-of-your-hand?
If internal case 'round it, which specific one?
liquidsnake757
