Best apps for rooted Note 3
Jeremy, that depends on the date of your kernel. If it's before June 3, 2014, Towel Root. If not you'll have to search for something.
You can also installed greenify to save youR battery and hibernate when you are not using the apps & to stop them from lagging your device. :)
I RECOMMEND XMODGAMES
I WILL ATTACHED IT,YOU CAN USED IT TO MOD CLASH OF CLANS AND OTHER SUPPORTED GAMES... :cool:
ENJOY AND HOPE IT WILL HELP YOU! :)
ROCK ON! :cool:
I just rooted my Note 3 as well and downloaded Ti-backup. Which apps is consider bloatware? Can you help with a list?
Any app you'll never use is bloatware. Whether you can remove any particular app is the question - an app you do use may use a process located in an app you don't use.
Freeze any app you're thinking of uninstalling. If the phone doesn't cause any problems after a couple of weeks, it's probably safe to uninstall.
ES file explorer
I think it's best file manager
Very important to have good pdf reader.
ColorNote for TODO
Google Translate with some offline languages
GPSTest for me important to see how many satellites available and their signal strenth
bruce03510
