best car charger adapter?
Neckteck charges it at a very high rate. No car charger will charge it as fast as the provided wall charger.
It's likely (assuming you use USB-C to USB-C), but the only review that mentions the Moto Z doesn't specify that it puts it into "turbo" mode.
USB-C to USB-C is not that common is it?
i only see USB-A to USB-C online to purchase.
so to clarify, the most efficient and fastest way to utilize the vinsic car charge is to use a type-c to type-c cable?
if you use type-a to type-c it won't charge in turbo mode for this phone?
Turbo mode seems to only work with either the stock charger or a USB-C to USB-C charging cable. The USB-C standard supports substantially larger power transfers, up to 100W in some applications (most laptops run 60-90W power adapters, for reference). USB-A doesn't support that, so an A to C cable is limited.
That said, not all USB-C chargers are created equal. The stock Z Force charger is rated for 5V/5.7A. The highest I can find in an aftermarket charger is 5V/3A.
thanks for the clarification.
aginaoghenechojakewho
