Best Car Charger?
Yeah I have it too - no problems at all.... used it few times.
I bet he has something bent on his plug.
The Motorola charger works fine for me on my Nexus. Not sure what the issue is on yours TundaBow.
Here is a picture of the stock N4 charger(left) and the Motorolla charger above(right). The only difference I see is the "slots" inside the plug. All I can tell you is the Moto charger is A LOT harder to put in and remove. You all's experience may be great, but to those looking to buy this charger, just know MINE is not right.
rapid charger is a danger for cell phone, you should never use it to charge your cellphone.
...or unless the the cellphone supports rapid charging, then its a non-issue. I always stick with original branded chargers that have the same amp rating as the stock charger.
http://i114.photobucket.com/albums/n260/foxracingktm/IMG_20130108_200924.jpg
Looks like in the review and in the pics, there are some that go out that are fakes! And some are real I guess? Weird. I'll have to check mine out.
Customer Image Gallery for Motorola Vehicle Power Adapter micro-USB Rapid Rate Charger
Interesting, thanks for the link. Looks like I got a legit one and it works fine for me. I'm actually going to order a second one for my other car. The weird thing is that from Tunda's pic it looks like his plug has the hologram sticker on it too.
jeffnachatilo
