Best Galaxy Note 4 Tempered Glass Screen Protector
All of this because Samsung, for some reason, didn't think the screen should be flat.
Well, and because this just becomes obsessive. :) As you indirectly pointed out:
A tempered glass protector that only covers the flat part of the display should be more than adequate, especially when used with most cases.
I gave up. Close is good enough.
I got a Nillkin Tempered Glass Film Screen Protector for my Note 4 but I have been having problems getting it right. Pretty sure I followed the instructions correctly but there's a few areas where it isn't completely flush on the screen. Would I be able to remove it and try reseating it or is that likely to encourage dust to stick to the screen or protector?
Gave up in the end. It just didn't sit right on the phone. Shame but should get a refund.
Having a look at the S-View flip cases with qi charging.
The side edges let in dust and junk under the glass. The glass would become unresponsive when the phone was in a few cases. I did not like the "Port Holes" over the Samsung logo and capacitive buttons.
Does the moshi work well with cases? I have the Samsung protective case, and it is a VERY snug fit - I don't think anything would fit under the edges if it extended that far...
Have the supershieldz 9h glass. I can live with the gap with a case on, but this thing is sticky
Actually prefer the shipping plastic which I had on there for a few days
ICarez glass 0.15mm has no halo or lift. Comparable to iloome screenmate flex but without the corner lift issue some have experienced. I'll post pics when I get my other phone.
sent from my Samsung GALAXY Note® 4
Yes, pics please! I'm wondering if this screen protector will lift up at the edges eventually like the iloome, or if it stays down for good. I was thinking about getting the Crown that Bodyguardz is putting out this month, but that's supposed to be $40-$45. Ain't nobody got time for that.
For a month the halo on my Note 4 didn't really bother me but now it's starting to get under my skin.
the super shieldz saved my phone during a nasty snowboard fall.. Just replaced it! Cheap, effective and I love it!
pmm09
