Best glass screen protector
I've always used the Whitestone Glass Screen Protector as it fits my phone well due to the all over adhesive and allows the fps to work.
It's not the cheapest option but the best especially for curved screens.
?????? Stay Safe ??????
Agree...although you will need to be an absolute scientist to get that thing on perfect. Your phone has to be level, you've got to get the liquid in just the right place, and you better clean and sticker clean the crap out of that screen before placing, or you're going to be out $30.
That and their warranty replacement is still going to cost you $20 and you've got to prove WITH PICTURES that you need a new screen. So if you need a new screen because your first attempt failed, take a picture of the failed screen in the garbage can...seriously.
Other than that, White stone all the way.
You can't go wrong if you follow the instruction. Watch some of the YouTube for guidance if you're visual person. I've done first one and it was perfect. Once you get over that fear, it will be fine. Also, if you screwed up, you can wash it off with soap of water (time consuming) and try again.
No, you absolutely can go wrong, despite watching the videos, having a level and being meticulous...because I did. Just because there's instructions and a video, it doesn't mean there should be no way something doesn't turn out anything but correct.
I'm not sure , probably have to ask , i know they will for ones they sell in the store .
Unless Whitestone sends the right box with the wrong screen and tray like they did with me.
They cost me a lot of time and trouble by sending my an open box special that was returned by a customer.
Worse they didn't inspect it.
They sent an Apple screen/tray in a Note 10+ box!
The backing on the screen had been tampered with as well.
They are off shore with no phone contact available.
So... me no likely!!!
liquidsnake757
