And you're still using the Trinity kernel? I am using the stock kernel, so I guess they're about the same. I find it odd that not many people are concerned with battery life, seems everyone wants to OC and tweak the ROMs to give performance over battery.
You don't have to be overclocked though. Particularly when playing with the minimum and maximum thresholds.
Here's mine...
Click to view quoted image
It's all in the tweaking.
Sent from Oliver, my Nuclear-Powered, Orb-Shaped Candy Device.
Will the tool box help improve battery life that much though? Not sure if I want to pay the 4 dollars for it? In other words, is it worth it?
I make it a habit of donating to devs I use frequently, so based on that, yes.
That being said, you can do a lot with the application. Changing speeds, governors, voltage, etc.
What kind of battery life do you get?
Honestly? I haven't really tested Oliver's sea legs lately. I can tomorrow and I'll let you know.
So I just switched over from Vicious v3 to Razor's Jelly. So far the battery life is awesome. The dreaded battery countdown is much slower and I'm getting a lot of "deep sleep" from the CPU. All the patches are in there and ROM is as pure to JB as you can get before the source is released. Give it a try.
[ROM] Razor's Jelly V2.5 [Verizon][Jelly Bean 4.1] - [VZW] Galaxy Nexus Development - RootzWiki
Now I kind of want to switch to razr jelly, but I don't feel like setting everything up again. If I didn't have to do a factory reset I would be fine.
Also, does it include all of the Google apps?
Edit: I installed razr. So far so good.
Ha ha - I see flashing bug has bit you! Yes - GApps are included along with its own kernel too i believe. Glad its going well for you. I'm going on 20hrs or so on Razor and the battery life is still the best of the JB roms ive tried. I got 14hrs on my 1st charge.
Are you using the stock kernel in razor? If you are, does your screen seem a little washed out? Mine did, and when I flashed the trinity kernel the colors became more saturated.
I cant seem to find data/local on phone. im using astro. Any help?
I am still trying to figure out how to do this . Can someone offer any assistance?
Edit :Sorry I didnt get the original post in. Had to do with putting the bootanimation file in data/local
If a ROM includes it's own kernel, will it overwrite any custom kernel that is installed? I like the thought of 20 hours for the battery.Ha ha - I see flashing bug has bit you! Yes - GApps are included along with its own kernel too i believe. Glad its going well for you. I'm going on 20hrs or so on Razor and the battery life is still the best of the JB roms ive tried. I got 14hrs on my 1st charge.
