Best LED-control app for stock 4.1 GS3?
wilder_jw
57
I rely on notifications quite a bit, because my phone is almost always silenced. Which app works best and has the largest amount of possible customization? (Note, I want to stay stock.)
Yeah Light Flow seems to suck large on the SG3 at the moment.
<< Sent from my SG3 using Tapatalk >>
I'm a fan of NoLED. Used it on my GS2 with no LED notification. Now I hate using the LED on my GS3. You can set it so a little picture of the person shows on your screen or you can set it to an icon.
It also has a setting so you can see the battery percentage while it's charging as well as a timer to turn off screen notifications. I use this between 1130 pm and 5 am.
Sent from my SGH-T999 using Android Central Forums
