Best screen protector I've ever used on the Honor 8
Yeah when my skin arrives today I think I'm going to install it and take off my screen protector and reapply it correctly and more carefully. I just hope I can get it to stick properly from taking it off so many times. I'll give it a try though bc now I want it to be straight knowing it's off lol
Take a picture after it's done so we can see!
I honestly think you guys should order this one. It will still give you plenty of drop protection but mainly there is no evidence of a halo. It you're anything like me that's a huge deal. I highly recommend ordering this screen protector. I have no doubt that you will be glad you did and love it.
I will definitely consider it. I have been running with out a screen protector for over a year and there are a number of scratches on the screen already
Oh that would drive me crazy. Yes get you one!!! You won't regret it. You can barely even tell it's on there.
I just took my screen protector off and I have a tip for all of you who want to reuse a screen protector that has gotten stuff under on the glass itseld. Take it to the sink and douse it with dishwashing soap and spread it evenly on the screen then grab a wrag and wet it and then proceed to pretty much scrub the back side of the protector while the soap is on there. Then after you've cleaned it well wash it off under the running water until all the soap is gone. Then dry the front side of it off with something but be sure you don't touch the wet back sticky side. Bang it a couple times on it's bottom edge to get as much water off as you can then take a credit card and swegee the rest of the standing water on the back sticky side off until dry. Then you now have a perfectly new screen protector ready to install. I know this works as I've done it several times in the past and I've done it twice with this one I just got from either something getting under the screen protector stuck on the sticky side or I've gotten fingerprints on the sticky side so I used the process on it I just explained and it's as good as new to reinstall. I'll post some new pics of it installed accurately now and you will notice when I post pics that you won't see any smudges on it as I washed them completely off with the soap and wet wrag. It really works great and will save you money from ordering a new one thinking that you've ruined yours by taking it off and getting dust and fingerprints on sticky part. You can just wash everything off and you have a new protector again.
Thanks for the tip!
Heres my screen protector reinstalled. I still think I may have gotten oh so slightly still off center but it's so small that I can live with it over my last install.
Same here as I never use a phone without a screen protector as if I scratched my screen it would bother me to no end. I immediately put my screen protector on my honor as soon as it arrived before even using it.
I would get the accessories before my phone arrives. Gotta be well protected and intact if I decide to sell it
Yeah as soon as I knew I was getting the honor 8 again I immediately ordered my screen protector I use for it. That way it would arrive at the same time. I actually installed this screen protector before I even turned my honor on.
Same. I actually got my cases and screen protector couple of days before my Honor 8 arrived. I was well ready for anything
Xpornefar
