Best slim high quality case
Is that easy to take in/out of pocket? Does it slide easily?
The exposed silicone at the top and bottom are a little 'grippy' but the hard shell is smooth and slides easily. I have no troubles taking it in/out of my pocket.
The reason I went with the case is the silicone over TPU. From past experiences, I find silicone handles impacts/drops better.
Additionally, it has a good amount of 'lip' for screen protection, or so I'd hope.
I ordered the ballistic aspirations case and diztronic TPU. GOT THE ballistic case in green and really liking it. It adds some bulk. But not much imo. It should be bulkier than the TPU case for sure.once I get that case I can better compare.
As for ballistic case, I do like it. Easy to hold, has great corners protection. And I like the green. I'm hoping when my screen protector comes in. It fits within the case.
If you are looking for ultra thin case, this is not It. But I think it's relatively thin and gives good protection.
Sent from my LG-D800 using Tapatalk
Ashok Dharshan
