Best ways to prevent/do away with lagging on the charge?
Than what would be the point of a memory card? Especially when some apps need the memory card to work, like medscape for example.
I'm not saying don't have a memory card.this is just for trouble shooting purposes . To show its not a lag due to the system. Its due to the phone scanning the sdcard.the more data on the sdcard the longer the scan time
Sent from my SCH-I510 using Tapatalk
VOODOO is your friend. If you want the most out of a Samsung phone, learn about Voodoo.
That is all.
I checked the market for Go Launcher and only found Go Launcher EX. Is that the same?
Thanks for all the info folks, it is greatly appreciated. I was outta town today so missed my delivery but my charge will be here in the am. I think I'll be installing go launcher first thing for smoothness. I cant wait to box this tbolt up and send it back to big red.
I tried using go launcher last week and I still prefer launcher pro over it. I just can't stand the horizontal scrolling in the app draw with the go launcher. With launcher pro you have the 3d app drawer like on the stock gingerbread on the nexus S.
I still have some lag even with launcher pro and disabling window animations. I may root in the future, especially if CM7 comes out with support for the charge.
Sent from Droid Charge using Tapatalk
I still have some lag even with launcher pro and disabling window animations. I may root in the future, especiaylly if CM7 comes out with support for the charge.
What exactly is CM7? Is it the Mack daddy ROM?
I downloaded Go Launcher EX last night.....so far, so good! SMOOTH as butter! You can switch the app drawer to vertical scrolling in the settings. One of the first things I did!
Thanks for the info, guys.
Even though its vertical scroll I'm spoiled by the 3d effect in the app drawer just like the stock gingerbread on the nexus phones.
start up lag is due to memory card scanning, try backing up all the contents of your memory card to your computer, then format the card and startup should be alot faster
Anybody who wants decent performance from SD storage (especially apps2sd) on this phone needs to replace the SD card. Put in a Class 6 card, or better, if you want it to do well running apps and reading/writing data from/to it.
The Samsung DROID Charge ships with an incredibly slow Class 2 microSDHC card. They cut a big corner there in performance while keeping the sales specs looking good by putting the slowest card they could find in it and only stating the capacity, so that 32GB card isn't such a selling point when they didn't even bother with a mediocre Class 4.
Reactions: KB3MMX
Class 2 SD cards Suck !!
Exactly!!
It is a Disgrace that they put a piece of CRAP Class 2 card in this phone just so people would get excited over the 32Gb capacity.....it's slow as hell and completely unsuited to ANY device that Videos in HD.
Major flaw from VZW morons or Samsung !!
Anyway, put a better card in the Charge and the performance jumps to life!
I run a Class 10 card and the phone is extremely snappy!
I have a Droid charge being sent to me to replace my disastrous thunderbolt. I'm pumped about having a stable device again but I am concerned about the lagging issues. What are some ways, tips and tricks, whatever you want to call it, ways to prevent or do away with lagging?? Non rooted by the way. I would love to root but I get very intimidated just when reading the root instructions... Anyways... TIA
Mine seemed to have diminishing lagging the first several days, maybe up to a week. The phone now is fast and smooth after use ad getting all my apps setup.
I don't understand why it did this but my HTC Incredible acted the same way when it was new then became smooth and fast.
The new EE4 update just sweetened it up even more!:D
Mine came with a class4
Mine had a clear "2" on the card.
Maybe they realized their mistake of putting a improper speed class 2 SD card on some of the early Charge's.
Would getting a higher class be a significant boost in performance if apps/data were moved to the SD card, versus it being on the phone (by default)? I only ask because I've got just under 1GB left in the internal memory, and that's with most of my apps installed. So I've got plenty of room.
But if there's a system-wide performance boost with an SD card, I've got no issue with upgrading.
Mine came with Class 2. 3 weeks old, purchased at Costco...
I'm also curious if there'd be a significant boost in speed if I put in a higher class card. Cards are cheap.
Crghjuygf
