best wireless charger
Charapa
16
"LG wireless charging pad", LG WCP-300 - walk/run to your nearest verizon store (&/or get it online), $39.99, black 'hockey puck' looking thing, no N4 slippage, no trick to positioning the phone, auto shut-off after charging. Been using it for a few days, no problems whatsoever.
Does it completely shut off when the phone is charged or does it turn on and off as needed? I keep my phone charging all night when I am asleep and dont want to wake up to a dead phone because the charger shut off
How well does it work with the n4 wearing the OEM bumper?
Quite well. That's actually my preferred method of use, as I found that without the bumper, the smooth glass back requires the puck to be on a completely flat surface, or else the phone will show you how capable it is of being a level and tell you fairly quickly which way the surface is sloped.
I just got the LG base and it works fine once you get the placement down. It charges just fine through my Boxwave Minimus case. The puck design is ok, but I wouldn't mind an oval shape with a bit of a cradle to it so it was harder to bump off or miss the sweet spot. The price seems a bit steep for what it is, but even wired phone-specific chargers aren't much less expensive, if at all.
All things considered, it is MUCH better than trying to plug that annoying Micro-USB connector into my n4 in the dark.
2 months, works w/ no issues. I hardly look at it before placing my N4 on it, again, no problems.
After using the LG version for a while, the flashing green indicator light is WAY too bright in the dark. I also wish there was a way to turn off day dream mode after a preset amount of time.
Does it work with Nexus 4?
I got my CHOE Qi Wireless Charging Pad for Nexus 4 Samsung Galaxy S4 and Iphone 5 Black in Color from Amazon at $24
Works with any Qi-enabled device through an adapter or an embedded chip
Power Source: AC Adaptor plugs into charging pad
Freedom of Placement: No annoying magnets to align or secret spots to find in order to charge your device. The wireless charging pad is Qi standard, you can charge any Qi-enabled device today, tomorrow and beyond. Light indicator to show charging status.
It works well with Nexus 4 smartphone.
Update - works with the N4 cased, both with a leather folio type & a cushioned pouch. No complaints.
I too have CHOE Qi Wireless Charging Pad for Nexus 4,Samsung Galaxy S4 and Iphone 5 Black in Color from amazon,its a great one
I have used it with my Nexus 4 with no challenge
i'm the only one that nexus 4 in naked mood slips when using the wcp-300 ? and why does its charge so slow
I have not timed the charging (I drop the N4 on/pick it up & go, throughout the day) so I can't comment on your question. The slipping issue, initially yes when I placed the charger on a unstable table (no pun intended), maybe change your charging location? it has 4 small pads underneath, check if any missing?
all 4 in place...
wobblefix
