Beta One UI 8 Preparation
I have to give them credit for releasing a beta so fast. This is the fastest I can remember them releasing a beta with the newest version of Android in years. Hope this is a sign of great things to come.
Definitely the fastest but the rumors were after One UI 7 failure that they would bring one UI 8 very fast and they did it just waiting on my Fold 6 to join
I've been running the beta for over 24 hours now and everything is working just like it did before. I does feel a little faster and I'm really surprised on how stable the first beta version seems to be. I was initially concerned that I'd have issues with Google Wallet and Ticket Master however they both seem to be working fine.
Same and battery life feels better than one UI 7
Reactions: mclarryjr
We are also on May build so no June came with this also was on April Play system so that's now also May
Reactions: jamezr
I took my chances and installed UI 8 this morning, so far, everything is working flawless, fast, and at least on my S25U, very stable. The Tesla App works fine, key is connected to the car and is working fine, just like before. I have the feeling that One UI 8 beta is the stable One UI 7.
Thanks @bhatech for that screenshot. I clicked so quick I only saw 'Unlocked' and was questioning why my T-Mobile device got through.
_______________________________________
My guess on why only T-Mobile is included because they alter device ROMs, not just Samsung, the least if at all out of the big three.
___________________________________________
Observations:
New Default USB-Mode = from MTP to Charging (smart security decision)
Surprisingly, a lot is working.
- Immediate Google Play System update available.
- GoodLock and most modules** a lot of modules
- Clock looks fixed
Not Working:
- My theme, not behaving the same as OneUI7 which was altered because it didn't work right there EITHER. Can't get the transparency to go away. Bug?
- No NavStar, QuickStar,NotiStar,MultiStar. **Discovering that while not grayed out, HomeUp doesn't work, sure others don't either but haven't checked them all
- DPI seems off. The font seems to look zoomed in some places and normal in others,
I downloaded OneUI Beta last week and I am loving it.
My only issue has been that I had started using GoodLock's HomeUP a lot. Since its not supported yet in the beta, I lost all of my home page formatting.
Luckily, I was able to fall back on my Nova Prime setup, that was very similar to what I had in OneUI 7.
Good lock module that are missing are coming soon for beta one UI 8
If anyone uses AdGuard and rely on Google Voice in any way, I just noticed today it blocks calls since the beta. Disable routing of Voice to fix it for now. Issue submitted on GitHub.
As for GoodLock, really the only thing I need from the ones missing are to hide the stupid VPN key and to get rid of the Recent's carousel view.
(Rhetorical) How is it that this Beta feels more complete than the "Stable" Android 15 that it shipped with?
Reactions: Laura Knotek
BekaH
