[BETA][ROM][MIUI] Rawrzilla Beta 2 By Team A.P.P
Re: [BETA][ROM][MIUI] Rawrzilla Beta 1
Can we just package a ROM with the default ICS dialer instead of MIUI? Because I got dialer to work on thekraven's UI is a no go..
Am I being "rude" here?
Can't do that. It will give you the same results as right now. If not, worse. (no service, etc.) The only reason it looks different is because the framework-res.apk makes it look that way. Not a different app, just a different theme. That kind of describes MIUI perfectly. Still ICS and CM9, just themed
Only rudeness I'm seeing here is that I'm saying that I'm working on it and yet you still complain about it. Nothing too bad, so don't take it the wrong way. It wasn't rude.
Sorry... Won't bother you about it any more...
Thanks....
Problem!!!!
When I get a call it force closes
Phone still FC occasionally
Getting better but I will wait for next beta:D
Sent from my LG-LS670 using Tapatalk
I downloaded ES File explorer from the Market and it won't run on this ROM. Anyone else have this problem?
I wanted to update to the newest MiLocker, but it says I need to uninstall the previous version first.
I can't find it in root explorer...
Any chance I can update it?
The latest update added mdpi support for most lockscreens
I can Confirm >.> ill take a look later(in class)
O.o it did?!
EDIT: Hmmm... >.>
Not that i found
Reactions: sundash22
O.o it did?!
EDIT: Hmmm... >.>
Not that i found
is MiLocker removable?
since its part of the themer, it seems like it wouldnt be, but most lockscreens are for hdpi...
only way i can hang up a call i have to put the phone in flight mode.
can't recieve phone calls, just phone crashes instead of ringing.
I'm on lewa right now but as far as the lockscreens not working on mdpi screens at first they didn't work, but now I can download any and it works fine. We may have to wait until this ROM is synced with miui source again.
personally think it should of stayed in alpha until phone and data work as they should.
Reactions: aaronrw
I honestly agree. I was getting ahead of myself thinking phone was completely solved... But that just means i gotta try harder...
NEXT RELEASE will most likely be synced with newest MIUI release.
Hey guys ( great rom me ) I have a bug. I can't install any apps from the market, I keep getting a -101 error can someone help I don't know what that means.
*can someone help me*
am i able to flash this rom
i have cm7 before that rom my baseband was zvd and i never went to zvh
also where do i get the kernel from
kernel is built in. Yes you can flash it, but be sure to do a clean install (Wipe everything)
Reactions: colstona1024
Anywhere close to fixing phone?
Is this discontinued at a couriosity
Sent from futuristic optimus s
I have updated mine to 2.3.16 but I'm still having the same problems as before (Phone still FCs). I'm still going to look into it but until I fix it I'm not going to release a new update. Me and me2151 have discussed this recently but haven't really taken any actions.
BeshevGames
