[BETA][ROM][MIUI] Rawrzilla Beta 2 By Team A.P.P
I have updated mine to 2.3.16 but I'm still having the same problems as before (Phone still FCs). I'm still going to look into it but until I fix it I'm not going to release a new update. Me and me2151 have discussed this recently but haven't really taken any actions.
Ok
Sent from futuristic optimus s
Re: [BETA][ROM][MIUI] Rawrzilla Beta 1
Guys. i have been busy but i keep looking for solutions. i will not be updating the rom until i get FCs solved. I currently recommend using the Cold As Ice rom until i release a new update.
Thanks -Me2151
I need a tester(or 2) for phone FC fix. i dont have ZVD right now as im working on ICS for ZVJ. please pm me.
@me2151im working on ICS for ZVJ
cant wait to see it
very nice
Ok my tester says phone does not crash so im going to clean up the zip and include a different kernel(its currently gingerkernel) Then release as beta 2.
Problem
Gapps dont work says installation aborted so i flashed kravens ics gapps and i got my google account but no market please help me
Problem
ill check it out.
EDIT: what doesnt work? its working fine for me
As many issues as you have with all of the different roms you flash, I would start looking at the way you're flashing or maybe even a hardware issue.
Added this ROM to the Welcome Guide. Thanks for all your work in getting this to daily driver level!
Gaps won't install I'm using YOUR gapps it says installation aborted
i Can install AND use my gapps market works fine and everything.
I recommend what Buddlespit says because with almost every rom you install you have problems no one else has.
Thanks. But credit goes to Team A.P.P. not only me anymore :D
BTW I don't have problems with every rom its just miui if you like I will make a YouTube video to show what I did here's what I did
Stock froyo
Reboot recovery
Factory reset
Wipe cache partitions wipe
dalvik cache
Flash rom
Wait.... success
Flash gapps.....
Installation aborted I never had problems like this before
Stock froyo
Reboot recovery
Factory reset
dalvik cache
Flash rom
Wait.... success
Flash gapps.....
did you disable signiture verification?
Team A.P.P, just so you guys know it is a GPL violation (and therefore illegal) to include a custom kernel (or any kernel really) without at least posting a link to the source code. Please do this ASAP.
heritagevine14
