Big problem with S22 Ultra...
fox2024
13
3
3
I have a Samsung mobile s22 ultra
Two weeks ago, when I ran any application my phone freezing with overlapping colors on the screen, and then it restarted automatically. The problem happens by chance. It can happen after an hour of use. It can happen after 10 hours. It can happen after a day.
Solutions I tried
1- reset setting
2-wipe cache partition
3-wipe data
and nothing I still have the problem
Reactions: gendo667
Welcome to AC!
Try the device in safe mode this will turn off any 3rd party apps if it's ok then suspect any apps you download.
Reactions: gendo667
thank you for your reply
I have been trying solutions for two days. Now I deleted the truecaller application
The mobile phone has been working fine for two days. I do not know the problem from this application or not
Hi
Ok keep us updated if that's the fix
Reactions: gendo667
I found this
I found this
I yours the Exynos version or Snapdragon? Snapdragon is US (and Canada?) and Exynos is rest of world (mostly)
@mustang7757 It's been a while since I flashed any kind of software to Samsung devices. But as I recall, Odin (if that's what is still being used) had an option to keep old data when flashing a new ROM. It used to never be recommended due to data conflicts. I'm curious if a complete reinstall may work?
The video narrator did say they had someone reinstall the software via computer, but they didn't specify what program. I am personally assuming whatever happened was done to preserve personal data, which then makes that possible solution still on the table.
Edit Reason: The tag was split, and I wanted to make sure it would work. Also some odd quirk that half the text was bold....no idea why.
Reactions: mustang7757
Yea still Odin and you can save user data, they can try to reflash the stock firmware , based off the comments OP mentioned I'm not sure if they tried safe mode , OP also mentioned has 2 apps Facebook messenger/Whatsapp but then deleted a third app True caller so I think it's best they take it in to have someone see this in person to see what's really going on .
famhesnes
