Bigger battery same size
Dizzo1992
254
Hey found a bigger battery but it still fits like the regular s3 battery. The question is to actually see if there is any improvement. I got it in the mail today its a 2900 mah instead of a 2100. It still fits the same and i don't need a special back for it. Im gonna drain it to 0% then charge it fully (Think that's what im supposed to do the first time.) Then ill see if it last better than my stock battery. Here is the link it was cheap and comes with a wall charger!
New 2900mah Battery + Charger for Samsung Galaxy SIII S3 i9300/T999/i535/L710 | eBay
Let us know how it turns out. I would be wondering though as it is very cheap and the same size. I doubt if the OEM folk just put filling in the battery to make it the size it is but hey let's wait and see.
Mike
will be interesting to see but i think if that kinda technology is around for that price, samsung would have used it. will be great if it works though :)
....maybe if it does work, the battery will only give u like 3months use before deteriorating
not because its not samsung... just because there must be a downside to it or all the OEM's would be using it
Ohhh I see... Well if it starts going bad ill just switch back to the original. Shouldn't do anything for my phone. Just wanted a back up just in case for road trips black Friday and stuff where I'm out all night.
Sent from my SCH-I535 using Android Central Forums
I personally wouldn't try it. The samsung stock battery is 3.8V...this guy is 3.7V. I'm not fiddling with current voltages and such just for a little longer battery life...
the stock battery is only at full voltage for a fraction of a second though lol. i wouldnt worry much about the voltage
Says it has 3.8 on the battery. I switched back to regular for now it's kinda scaring me don't wanna mess us my phone cuz I love this thing lol.
Lol if my phone explodes you can call chip in for my replacement :p
no problem mate ill send it in ?'s :) seriously though is the current the same as the stock battery?
Lol. Good find of it works. Could be fake though. I've read reports of company's using lower powered batteries and just putting a label on it that says it's higher. Might want to pull the label off and see what mah the battery really is if it doesn't work like you think it should. Let us know though. Try it for a day or 2. If it's good I'll pick it up for myself.
And funk. Samsung might've been able to squeeze a little more power in if NFC wasn't in there battery. So there is the possibility they could pack more juice in such a small pouch
true man i hadnt thought of that. i dont even use NFC so if batteries like this are any good, il defo be gettin one ;)
Alright I put it back in. I'm gonna drain it down and I guess the real test starts tomorrow see how it holds up compared to the original.
Reactions: sardar615
...think theres battery discharger apps that turn vibrate, screen, flash etc to run a battery flat faster
