Biometrics update rolling out
I got the update last night and am pleasantly surprised. FPS is working wonderfully. Loving my S10+ as my daily driver.
Same exact thing here. I had a bad WiFi connection, though. Tried twice then let it sit (planning to try once I got to a WiFi) but now it's gone without a trace and still on 4.1
Notification returns with a restart. Installed no problem. fPS actually better, but not perfect. That's OK. Shows software can improve it.
Got my update also last night (on VZW), i was surprised. Deleted all my existing fingerprints and reregistered. Seems quick, only time will tell.
was working pretty poorly before the update. much improved now. went from 25% recognition to about 90%.
Yeah I deleted mine and redid it. Seems to be ok now actually. Maybe it had to settle in a bit. Lol.
What I found that works best so far for me when recording prints is too not mash down when it says press a little harder. Press just hard enough to register. If you record a mashed print it is harder to duplicate when reading.
This is why I say they should add this to a future monthly security updates which gets burned into the ROM.
This way everyone gets it, and if you do a factory reset it will still be there.
I hope they don't keep it as an app update.
Hi all,
I think an improved version is released ..
I was able to install the one rolled out today.
Please check again and let me know.
Thanks!!!!!!!
Hi all,
Thanks!!!!!!!
Hi all,
Thanks!!!!!!!
Are you saying it is more recent than the recent one last week?
Please post the version number
kurniaa
