BlackBerry Hub on Mate 10 Pro
Maybe.
I didn't do anything in the settings to get it working.
Gotta wait for OP to get back from his business trips and check it out
Thanks for all the feedback! I should have the access to the M3 when get back home, around the end of the week.
I will post the result for sure!
Maybe.
Ok. Well there's always the fdr option though that's a last resort. It has worked for me in the past fixing an app that wasn't working though.
If factory reset works then OP should try it. Of course back up your data first.
So far everything is working just fine. If you want, you can download the apk version to get it working like I did
roksakure
