I'm installed the BlackBerry Hub on the S9 after reading that others found it works fine. All is working fine for me except after showing the beginning words in the list of an incoming text, subsequent texts to and from that same person in that same thread over hours failed to result in the listing in Hub refreshing to show any of that recent text. On my KeyONE it didn't update to show my outgoing replies but did always show the most recent incoming text in the given thread from the given person.
I was using Verizon's Message+ app in both cases at first so to double-check this issue on the S9 I then switched to using the default Messages app that came with the S9 (I added the Message app to the Hub accounts to list) and the same issues exists -- it does reflect the first incoming text from someone but not subsequent ones.
The S9 is running Android 9.
This is really not good, since the Hub is failing to inform me of new incoming texts.
Any suggestions?
Any suggestions?
