Blocked Call Notification - How to Turn Off?
That is not hiya. Lol.
Preinstalled on mine as well. Maybe Samsung uses their service for the blocking. I have no idea. Just know I didn't download it.
a couple of folks here talked about it being there and then I saw it after I went looking for it. but it's not in the app drawer. only in the apps in settings.
What else does it do the app if you download?
It blocks phone calls and keeps a database of millions of numbers to block and works great. Also blocks spoof numbers that resemble your own prefix.
The built in one is just a callerid.
so? that was a fork. it was something I said I saw. you're the one who was all no you don't have it. but I do *shrug*
But you don't. Read what it does. It's just a caller ID info and does nothing else. Want to stop the scam calls get the real app.
On the S10, Go into settings and scroll down to apps, then select in the right top corner the 3 dots and click "show system apps" and scroll down to "Call Settings"
Hi, Welcome to the Forums!
did this work for you?
Yes it did. It was driving me crazy. Found something similar on another forum about the 'show system apps' tip and then I found the 'call settings'. Just made notification silent.
Great , thanks for the tip
stantn
